Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Dual USB Connector, usa il nostro manuale di assistenza.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: passo 1, immagine 1 di 1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: passo 2, immagine 1 di 2 MSI Dual USB Port Bracket Teardown: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Phillips #1 Screwdriver
    $5.49
    Compra
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: passo 3, immagine 1 di 1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
Membro da: 04/07/10
415 Reputazione
2 Guide realizzate
Un commento
Why does it need its owe usb header just for the LED's.
Rick Acker - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 34
Tutti i Tempi: 7,763
