Introduzione
On This Segment of Hp 625 Teardown, You Will Learn How To Disassemble and Build More Skills Towards Your Endevour.
Parti
Nessuna parte richiesta.
  1. Overview of Hp 625.
    • Overview of Hp 625.
  2. Front View of Hp 625.
    • Front View of Hp 625.
  3. Removal of Hp 625 Battery.
    • Removal of Hp 625 Battery.
  4. Removing of Hp 625 Battery.
    • Removing of Hp 625 Battery.
  5. Hp 625 Battery Removed.
    • Hp 625 Battery Removed.
  6. Unscrewing Hp 625 Service Door (4 Screws).
    • Unscrewing Hp 625 Service Door (4 Screws).
  7. Removing Hp 625 Service Door.
    • Removing Hp 625 Service Door.
  8. Hp 625 Service Door Removed.
    • Hp 625 Service Door Removed.
  9. Unscrewing Hp 625 HDD, (3 Screws).
    • Unscrewing Hp 625 HDD, (3 Screws).
  10. Removing of Hp 625 HDD, (Gently Slide).
    • Removing of Hp 625 HDD, (Gently Slide).
  11. Hp 625 HDD Removed.
    • Hp 625 HDD Removed.
  12. Unscrewing of Hp 625 DVD Drive, (1 Screw)
    • Unscrewing of Hp 625 DVD Drive, (1 Screw)
  13. Removing of Hp 625 DVD Drive, (Carefully Slid).
    • Removing of Hp 625 DVD Drive, (Carefully Slid).
  14. Hp 625 DVD Drive Removed.
    • Hp 625 DVD Drive Removed.
  15. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  16. Removing of Hp 625 DDR3 RAM, (Together With Two Hands Expand The Clips a little).
    • Removing of Hp 625 DDR3 RAM, (Together With Two Hands Expand The Clips a little).
  17. Hp 625 DDR3 RAM Removed, ( Be sure not to Touch The Gold Plated Pinouts).
    • Hp 625 DDR3 RAM Removed, ( Be sure not to Touch The Gold Plated Pinouts).
  18. Unscrewing of Hp 625 Keyboard, (6 Screws Noted By Keyboard icon).
    • Unscrewing of Hp 625 Keyboard, (6 Screws Noted By Keyboard icon).
  19. Removing of Hp 625 Keyboard Flex Cable, (Gently Release The Locking Mechanism).
    • Removing of Hp 625 Keyboard Flex Cable, (Gently Release The Locking Mechanism).
  20. Hp 625 Keyboard Removed.
    • Hp 625 Keyboard Removed.
  21. Disconnecting of Hp 625 Power Flex Cable From Connector, ( Fairly Unlock The Locking Mechanism).
    • Disconnecting of Hp 625 Power Flex Cable From Connector, ( Fairly Unlock The Locking Mechanism).
  22. Hp 625 Power Flex Cable Disconnected.
    • Hp 625 Power Flex Cable Disconnected.
  23. Unlocking of Hp 625 Palm Rest, Through The HDD Bay.
    • Unlocking of Hp 625 Palm Rest, Through The HDD Bay.
  24. Disconnecting Touch Pad Flex Cable and Removing of Hp 625 Palm Rest.
    • Disconnecting Touch Pad Flex Cable and Removing of Hp 625 Palm Rest.
  25. Hp 625 Palm Rest Removed.
    • Hp 625 Palm Rest Removed.
  26. Unscrewing of Hp 625 System Casein, (16 or More Additional Screws Verify Very Well For Additional Screws Needed To Be Unscrewed Before Removing The Casein).
    • Unscrewing of Hp 625 System Casein, (16 or More Additional Screws Verify Very Well For Additional Screws Needed To Be Unscrewed Before Removing The Casein).
  27. Removing of Hp 625 Front Casein, (Firmly Pry the Casein, Starting from Any Edge).
    • Removing of Hp 625 Front Casein, (Firmly Pry the Casein, Starting from Any Edge).
  28. Hp 625 Front Casein Removed.
    • Hp 625 Front Casein Removed.
  29. Unscrewing of Hp 625 Thermal Fan, (1 Screw).
    • Unscrewing of Hp 625 Thermal Fan, (1 Screw).
  30. Hp 625 Thermal Fan Removed.
    • Hp 625 Thermal Fan Removed.
  31. Unscrewing of Hp 625 Thermal Conductive Heatsink, (6 Screws).
    • Unscrewing of Hp 625 Thermal Conductive Heatsink, (6 Screws).
  32. Hp 625 Thermal Conductive Heatsink Removed.
    • Hp 625 Thermal Conductive Heatsink Removed.
  33. Unlocking of Hp 625 AMD Processor From Socket, (Anti-Clockwise).
    • Unlocking of Hp 625 AMD Processor From Socket, (Anti-Clockwise).
  34. Hp 625 AMD Processor Removed.
    • Hp 625 AMD Processor Removed.
  35. Disconnecting of Hp 625 Wi-Fi Cables From Wireless Card.
    • Disconnecting of Hp 625 Wi-Fi Cables From Wireless Card.
  36. Hp 625 Wi-Fi Cables Disconnected.
    • Hp 625 Wi-Fi Cables Disconnected.
  37. Disconnecting of Hp 625 HDD Card From Motherboard.
    • Disconnecting of Hp 625 HDD Card From Motherboard.
  38. Disconnecting All Cables of Hp 625 Connected To Motherboard.
    • Disconnecting All Cables of Hp 625 Connected To Motherboard.
  39. Unscrewing Hp 625 Motherboard.
    • Unscrewing Hp 625 Motherboard.
  40. Removing of Hp 625 Motherboard.
    • Removing of Hp 625 Motherboard.
  41. Hp 625 Motherboard Removed.
    • Hp 625 Motherboard Removed.
  42. Complete Disassembled Parts and Components of Hp 625.
    • Complete Disassembled Parts and Components of Hp 625.
  43. 'Reparatur ist edel
    • 'Reparatur ist edel
Conclusione
Altre 8 persone hanno completato questa guida.
samuel
Membro da: 09/06/2013
361 Reputazione
1 Guida realizzata
You mentioned there are 6 keyboard screws. I can find only five. Can you be more specific (detailed) in where these screws exactly are. Thanks
simakos71 - Replica
Hello Simakos71, follow this YouTube link: https://youtu.be/91JQ596T0og to know strategic places the screws are located.
samuel -
Whats a good way to follow i really want to be repairing but i need your advice on how to start thanks
engiengimib@gmail.com
Ibrahim Musa Bello - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 9,175
