Make sure you have disconnected the power supply and removed it from the computer, letting it sit for 1-5 minutes to ensure release of charge, start this process with a medium sized screwdriver.
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Dell Power Supply (MH596), usa il nostro manuale di assistenza.
Remove glue surrounding the port that would be visible outside your computer(it is hot glue so it should be easy)
There are clips to pull the metal back and the black plastic through to help remove the black plastic, though I do not cover this it should never be necessary
After all this work of disassembling this as far as you could go you surely have seen the magnificence of how crucial proper power is to a computer and everything around us, from you to what your reading on right now, we all have one thing in common: we need energy
