Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Commodore 1341 Joystick, usa il nostro manuale di assistenza.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: passo 1, immagine 1 di 1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: passo 2, immagine 1 di 3 Commodore 1341 Joystick Teardown: passo 2, immagine 2 di 3 Commodore 1341 Joystick Teardown: passo 2, immagine 3 di 3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: passo 3, immagine 1 di 3 Commodore 1341 Joystick Teardown: passo 3, immagine 2 di 3 Commodore 1341 Joystick Teardown: passo 3, immagine 3 di 3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
Membro da: 04/24/10
118 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 7,012
