Salta al contenuto principale
Questo smontaggio è in corso – Ricarica periodicamente per vedere gli ultimi cambiamenti!
Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Strumenti necessari in questo Smontaggio
  1. The Assembled Product, unplugged from wall
    • The Assembled Product, unplugged from wall
  2. Turn Smart Strip upside down and locate  four screw holes in corners Unscrew four corner screws with #0 Phillips Screwdriver
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. Locate four latch slots in case Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  5. Take two halves of case apart with your hands Take two halves of case apart with your hands
    • Take two halves of case apart with your hands
  6. Lift Ground Copper Strip upward off of power plugs by hand
    • Lift Ground Copper Strip upward off of power plugs by hand
  7. Locate latch securing power plugs to bottom of case Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  8. Lift power plugs out of bottom of case along with circuit assembly Lift power plugs out of bottom of case along with circuit assembly
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
Membro da: 14/11/2013
194 Reputazione
1 Guida realizzata
This is great! Thanks so much!
nils smith - Replica
that awesome and i like how it fix
Joseph donkor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,127
