Strumenti necessari in questo Smontaggio
Introduzione
The only tools needed are a philips screwdriver and a narrow putty knife.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Belkin Express Dock, usa il nostro manuale di assistenza.
  1. View of the connectors
    • View of the connectors
  2. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed.
    • Use a putty knife to remove the four rubber feet. Once removed, there are 4 phillips screws to be removed.
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
    • The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
  5. Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
    • Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
  6. Front and back of the board. From left to right on the front of the board the major chips are:  LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • Front and back of the board.
    • From left to right on the front of the board the major chips are: LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • From left to right on the back of the board the major chips are: Parade PS161HDM; Parade PS8301 (two); NXP ZSD310 (two); Parade PS8321. The chips seem to support HDMI/DVI conversion and Display Port!
  7. close-ups of the major chips close-ups of the major chips close-ups of the major chips
    • close-ups of the major chips
thompsonfamily
Membro da: 21/01/2011
217 Reputazione
1 Guida realizzata
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,921
