Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Asus ZenWatch 3, usa il nostro manuale di assistenza.
  1. Asus ZenWatch 3 Teardown, Let's begin: passo 1, immagine 1 di 1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: passo 2, immagine 1 di 2 Asus ZenWatch 3 Teardown, Band Removal: passo 2, immagine 2 di 2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: passo 3, immagine 1 di 1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: passo 4, immagine 1 di 1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: passo 5, immagine 1 di 1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: passo 6, immagine 1 di 1
    • Battery
  7. Asus ZenWatch 3 Teardown: passo 7, immagine 1 di 1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: passo 8, immagine 1 di 1
    • Complete disassembly
Reon
Membro da: 02/01/13
141 Reputazione
1 Guida realizzata
20 Commenti
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Replica
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Replica
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Replica
What should I do if the power button doesn’t work?
MichaelKing10or - Replica
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 14,431
