Introduzione
Use this guide to separate the back panel from the display screen of your Asus Tablet MeMo Pad 7 ME7000C. Make sure you are using the proper tools and exercising caution while opening the back panel to avoid causing damage to the tablet.
Parti
Nessuna parte richiesta.
  1. Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off. Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device. If you are having trouble using the blue plastic opening tools, try using the black spudger instead. If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  4. Pull the rear panel and the display screen away from each other. Pull the rear panel and the display screen away from each other.
    • Pull the rear panel and the display screen away from each other.
Linea Traguardo
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 153
