Introduzione
How to take apart the Apple TV.
Cosa ti serve
We got our new Apple TV today, skipped the 'plug it in' step, and went straight to our disassembly. It's Apple model #A1218.
The packaging has been reviewed to death other places, so we're going to skip that.
Peel up the rubber base (remove the rubber carefully so you don't tear it) and remove the four T8 Torx screws beneath:
Two 10 mm T8 Torx by the ports.
Two 15 mm T8 Torx near the front.
The fan is mounted on rubber posts to dampen vibrations and make it quieter. Apple claims the Apple TV is 7-10 dB, which is extremely quiet.
Use tweezers to compress the top of a rubber post and push the post down into the hole. Repeat this for each rubber post.
Once all three posts are pushed into the fan, lift the fan up carefully. The posts should easily slide out, freeing the fan.
The top of the logic board.
The two SAMSUNG chips are DDR333 SDRAM, probably video RAM.
The chip with the SST logo is an EEPROM: SST 89V54RD2 33-C-TQJE 0649041-B2
Interspersed throughout the pictures are troubleshooting tips from Apple for when hardware failure inevitably strikes.
Flashing question mark: As most Mac owners are aware, a flashing question mark means the Mac can't find the OS-- signifying a bad hard drive or corrupted OS. The same can happen with the Apple TV, but Apple's suggested remedy is taking it in to an Apple Store.
No video: The Apple TV defaults to HDMI, so make sure you don't have HDMI plugged in if you want to use component video.
No video via component cables: Apple says to "Hold down the Menu and Menu up/scroll (+) buttons simultaneously on the Apple Remote for 6 seconds." This forces it to cycle through every resolution. Press play when it reaches the resolution you want.
Unpair your remote: To set the Apple TV to work with any remote, hold the "Menu and the Previous/Rewind (<<) button for 6 seconds."
Factory restore: According to Apple, "Press and hold both Menu and Menu down/scroll (-) on the Apple Remote for 6 seconds or until the status light blinks amber." Then select your language, and factory restore.
Networking: The Apple TV uses UDP port 5353 (Bonjour) and TCP ports 3689 (iTunes Library Sharing), 80 (iTunes store), and 443 (iTunes store).
LEDs: The status LED can be white or amber. Apple has a table listing all permutations.
