Salta al contenuto principale
Introduzione
This is definitely a destructive teardown. Hopefully it will help to show how the adapter was put together. Also that it does have a DAC on the adapter, not the lightning connector on the idevice.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Apple Lightning to Headphone Jack Adapter, usa il nostro manuale di assistenza.
  1. Typical Apple product packaging. Simple yet elegant Backside of the package Bottom of the package describes the adapter as a A1749
    • Typical Apple product packaging. Simple yet elegant
    • Backside of the package
    • Bottom of the package describes the adapter as a A1749
  2. Again, nice packaging for the adapter. The total length of the adapter is 3 1/8 inches or 8cm. One side with the lightning connector and the other end is the 3.5mm headphone jack. Checked to see if there was any way to remove the outside of the adapter by slipping some thin tools in between. No way on that.
    • Again, nice packaging for the adapter.
    • The total length of the adapter is 3 1/8 inches or 8cm. One side with the lightning connector and the other end is the 3.5mm headphone jack.
    • Checked to see if there was any way to remove the outside of the adapter by slipping some thin tools in between. No way on that.
  3. This is the business end that requires the removal of the covering. The only way to do that is by cutting into it. Using a good scalpel does cut it with relative ease. Careful while using a sharp instrument, not much room to hold onto the connector.
    • This is the business end that requires the removal of the covering.
    • The only way to do that is by cutting into it. Using a good scalpel does cut it with relative ease.
    • Careful while using a sharp instrument, not much room to hold onto the connector.
  4. Cutting length wise on one side as well as the opposite site Then flipping the two halves that were created by the cuts.
    • Cutting length wise on one side
    • as well as the opposite site
    • Then flipping the two halves that were created by the cuts.
  5. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  6. This makes for an easy removal. The next thing to be removed is the ground shield. Using a pair of small side cutters that shield is easily removed as well.
    • This makes for an easy removal.
    • The next thing to be removed is the ground shield.
    • Using a pair of small side cutters that shield is easily removed as well.
  7. Just a matter of using the cutters on one end and rolling it around the connector. This shows the destructive nature of this teardown
    • Just a matter of using the cutters on one end
    • and rolling it around the connector.
    • This shows the destructive nature of this teardown
  8. The connector is now left with another plastic covering. Luckily the removal of the ground shield seems to have open slots lengthwise in the plastic covering. Using these slots, the plastic needs to be carefully pulled away from the circuit board.
    • The connector is now left with another plastic covering.
    • Luckily the removal of the ground shield seems to have open slots lengthwise in the plastic covering.
    • Using these slots, the plastic needs to be carefully pulled away from the circuit board.
  9. Here is the business end with the cover removed. This side shows what appears to be the DAC inside this adapter Close-up of the circuit board shows Apple's fascination with adhesive and other sticky substances. Both sides of the circuit board are covered with it.
    • Here is the business end with the cover removed.
    • This side shows what appears to be the DAC inside this adapter
    • Close-up of the circuit board shows Apple's fascination with adhesive and other sticky substances. Both sides of the circuit board are covered with it.
  10. A bit more of a close up of one side as well as the other. As more information becomes available about the DAC this teardown will be edited to reflect those. Here are the markings on the DAC 338S00140        A0SM1624        TW
    • A bit more of a close up of one side
    • as well as the other. As more information becomes available about the DAC this teardown will be edited to reflect those.
    • Here are the markings on the DAC 338S00140 A0SM1624 TW
  11. Carefully slice down the headphone jack connector with a sharp knife, being careful to not cut yourself. Carefully slice down the headphone jack connector with a sharp knife, being careful to not cut yourself. Carefully slice down the headphone jack connector with a sharp knife, being careful to not cut yourself.
    • Carefully slice down the headphone jack connector with a sharp knife, being careful to not cut yourself.
  12. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  13. Considerazioni Finali
    • The device is clearly not meant to be opened or repaired in any way.
    • It is impossible to open the adapter without destroying it.
    Punteggio Riparabilità
    0
    Riparabilità 0 su 10
    (10 è il più facile da riparare)
oldturkey03
Membro da: 29/09/2010
599.377 Reputazione
102 Guide realizzate
OTS Membro di OTS
Business
1 Membro
130 Guide realizzate
There seem to be a lot more wires than necessary going to the 3.5mm connector. By my count there appear to be 7 or 8 discrete wires?
At most there should be 4, TRRS, and maybe a shield ground. How are the other wires used here?
Mac 128 - Replica
Mac 128 excellent question and I will try and take the jack end off as well asap. There is a total of 7 wires....
oldturkey03 -
Perhaps it supports both standard pinout methods for mics/remotes, rather than just Apples flipped data/ground pin standard?
tipoo -
I am currently looking into modyfying an Apple TRRS connector so I can take some readings on what is what and how it may function. Only hold-up is that I do work for a living:-) so time is always an issue.
oldturkey03 -
Mac 128 mystery already solved. Check this teardown by Mason Dowell Apple Earphones with Remote and Mic (Lightning Edition) Teardown. It'll explain what each wire does.
oldturkey03 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 41
Ultimi 7 Giorni: 229
Ultimi 30 Giorni: 981
Tutti i Tempi: 63,633
