Introduzione
My remote had battery leakage damage. I attempted to disassemble to clean but prying was very forceful and I probably damaged it. Also, I found the battery damage was extensive inside.
Cosa ti serve
Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
Very easy to remove with the #0 phillips screwdriver.
Once the screws are removed, all the pieces come out easily.
Un commento
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
