Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo 2010 Telstra t-box, usa il nostro manuale di assistenza.
  1. 2010 Telstra t-box Teardown, Preparation: passo 1, immagine 1 di 1
    • Place your system on a flat surface and make sure all cables are disconnected from the system before dissasembly
  2. 2010 Telstra t-box Teardown, Remove case from bottom: passo 2, immagine 1 di 1
    • Flip the device over and remove the hard drive cover (I dont have a hard drive cover on my t-box)
    • Peel off the warranty sticker and remove the 4 screws
  3. 2010 Telstra t-box Teardown, Opening it up: passo 3, immagine 1 di 1
    • Pull the casing off being careful of the cables connected to the case.
    • carefully disconnect those cables and proceed
  4. 2010 Telstra t-box Teardown, Getting inside: passo 4, immagine 1 di 1
    • After disconnecting the cables, you can remove the top half of the outer case.
  5. 2010 Telstra t-box Teardown, Disconnecting the USB wifi adapter: passo 5, immagine 1 di 1
    • remove the black tape holding the USB wifi adapter in place, then remove it the same way you would remove a USB stick
  6. 2010 Telstra t-box Teardown, Removing the IR sensor's board: passo 6, immagine 1 di 3 2010 Telstra t-box Teardown, Removing the IR sensor's board: passo 6, immagine 2 di 3 2010 Telstra t-box Teardown, Removing the IR sensor's board: passo 6, immagine 3 di 3
    • remove the ribbon cable on both ends and then carefully remove the IR sensor's board from the device
    • Please note that there is a metal tab thing holding the board in place, pull it a little bit and remove the board
  7. 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: passo 7, immagine 1 di 3 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: passo 7, immagine 2 di 3 2010 Telstra t-box Teardown, Removing the Main Board and hard drive: passo 7, immagine 3 di 3
    • Remove the screws holding the circut board in place
    • There is a screw on the hard drive cover next to the board, remove it
    • remove the hard drive and you should be able to get the main board
  8. 2010 Telstra t-box Teardown, And you're done!: passo 8, immagine 1 di 3 2010 Telstra t-box Teardown, And you're done!: passo 8, immagine 2 di 3 2010 Telstra t-box Teardown, And you're done!: passo 8, immagine 3 di 3
    • Take some nice pics of the t-box
    • To put it back together, do all these steps in reverse
Bryn Trainor
Membro da: 04/25/19
314 Reputazione
1 Guida realizzata
7Commenti sulla guida
once you’ve taken it apart, can it be repaired? we have lost picture … can’t play ANY recoded material (100 hours worth) … what to do?
omarty - Replica
It’s exactly the same as few other boxes, this is a Netgem N8200, comes with different model designations depending of hard drive, etc… N8200-320-2T, N8200-160-2T, N8500-…
BITS2 - Replica
I am no longer using this device with telstra-
Is there anything in there that could be used for anything else other than the t-box??
Or do I throw it in the bin!
Steve - Replica
@steve75385 Don't throw it it the bin! Send it to me. I would like to use the mechanical spinning thing that's encased in a silver aluminium box
ww w -
Is there a way to get recorded things off the hard drive? I have several movies on mine and the tbox won't power on any more.
Deanne Roberts - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,496
