Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2191 Domande Visualizza tutte
Why is the touch screen not responding?
The phone touch screen dosn't respond but the display work perfectly. I replaced the display but the same issue is persisting. who ever had the phone before me had done something because a screw is missing. ive also tried to made sure the touch screen cable was connected correctly.
Questa è una buona domanda?
Punteggio -1
1 Commento
are you positive you didnt tear the ribbon cable when sliding it threw the slot in the metal frame
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is a good chance the device suffered water damage. I would clean the digitizer connector on the logic board with rubbing alcohol let it dry completely and try again.
Punteggio 0
Aggiungi la tua risposta
xmoonxboyx92 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,332
