Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
What to do when my screen stay white?
Even after a restart, my screen stays white, should I ship him to apple or someone got any other idea?
Questa è una buona domanda?
Punteggio -1
2 Commenti:
Depends on what type of iPod do you have, which one do you own?
da
Ipod classic 5th or 6th generation
da
Aggiungi un commento
1 Risposta
Dominic, for what it will cost you to ship it to get repaired, you might as well do it yourself. I would start by opening it up and checking the display connector. the white screen only means that the backlight is working, no data. If your cable and connector are okay, replace the display. Not a bad job, but it will require you to properly identify your iPod. the displays are different even so the task is the same. Use the guides from here to get it done. Hope this helps, good luck.
Punteggio 0
Aggiungi la tua risposta
Dominic sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 451
