Salta al contenuto principale
Subaru Indiana Automotive ha iniziato la produzione nel febbraio 2004 per i mercati nordamericani per l'anno modello 2005.
2005 Liberty/Leg GT (aus) Er HC which is Can Error.
So far I have checked all the earths and change them in the engine bay. checked all the fuses in the engine bay and under the passenger/drivers and changed the orange relay on the passenger, I have no access to ecu through the ob2 with ssm3 key turn to on as normal and all i hear is clicking of a relay but no crank on the drivers side.
changed the battery, starter motor and intake. I don't here the fuel pump now but it was going before i changed the relay, first time ive been stuck this bad with this subie and dont know where to go from here oh yeah ive also tried to get the codes from the on board dionostic cobination meter but all get is flashing letters no numbers.
any suggestions would be great. i have a spare biu and ecu but havent got the tools as yet to make a doner ecu which will be next on my list.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
The OBDII error codes are generated and turn on not only the check engine indicator but other indicators. Emissions errors are P type codes turning on the CEL (only). B, C, and U codes do not turn on the CEL but will turn on other indicators (abs/tc/esc/vdc, Eyesight, etc) If you can see all the indicators cycle on at ignition ON time, then see most cycle off, you are seeing the general power-on self tests being performed with indicators having value. If you can see the check engine indicator cycle on then off, and remain off during starting (or at least turning the ign switch to START), there won't be any P codes. The same for other indicators. If they cycle on then off, they performed their own POST within their module and turn off if self tests pass. Example; the abs indicator cycles on and off after ignition ON time, indicating the entire abs electronics has passed its own self tests before starting the engine. If at any time the abs indicator turns on and remains on, there's a (C) code stored that most readers cannot decode. Better, higher cost readers can decode P, B, C, and U codes. All by observing the "idiot lights", every indicator and how each one cycles on, off, remain on or cycle on after starting and driving. Low cost readers will not decode B, C, and U codes (their indicators are the first clue to stored error codes). Better readers decode the hidden errors the CEL doesn't store.
Here's link to service manuals that may help insofar as the starting circuit; https://lemon-manuals.org.ua/Subaru/2005.... This is for the 2.5L engine. Wander around as you feel comfortable to find whatever helps. Be aware that the starting circuit must have the Park/Neutral safety switch closed, factory security system disabled and fuses intact, relays operating to meet the BIU's criteria of allowing a START. In one way, if you can hear a distinctive loud metallic click always associated with the large starter relay/solenoid on the starter but do not hear the starter motor cranking the engine, this tends to point to either a starting circuit, wiring or starter motor issue.
One shortcut to diagnosing/troubleshooting you can try but must either crawl under or stand over the engine and jumper across starter terminals, main battery terminal connection to the small terminal. The small terminal is the START command signal (12v) to power the starter solenoid piggybacked on the starter. As soon as the starter solenoid is powered up, it pulls the starter gear into the engine flywheel while simultaneously closing heavy duty electrical contacts to allow full battery power to operate the starter motor. A screwdriver or if you're not interested in seeing electrical sparks during the jumper attempt, making up or buying a remote start switch with a pushbutton wired between two wires with alligator clips to clip onto the two starter terminals. Once connected to the starter, pressing the button does the same as using a screwdriver or needle nose plier, shorting the small terminal to the large terminal. If you see and hear the starter power up and crank the engine, you effectively bypassed security and starting circuits, verified good power wiring, good ground(s) between battery and chassis.
Punteggio 1
Aggiungi la tua risposta
D W sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 52
Tutti i Tempi: 94
