Salta al contenuto principale
Informazioni su riparazione, smontaggio e soluzione problemi per il Microsoft Surface Pro 11. Il dispositivo è stato rilasciato nel giugno del 2024 con il numero di modello 2076.
Will the Surface Pro 11 5G OLED panel work in the Intel/Business Model
Hi,
I have a Surface Pro 11 for Business, Model 2103 (Intel Core Ultra 7), with the original Samsung OLED panel marked ATNA30DW02-0.. The Surface Pro 11 OLED Screen is out of stock, but the Surface Pro 11 5G OLED Screen is available.
Can anyone confirm if the Surface Pro 11 5G OLED Screen is compatible with Model 2103?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hello,
I would ask support@ifixit.com about this.
Punteggio 0
1 Commento:
Hi, Thank you for the suggestion Theo. I've already contacted support but the reason I put this question here was to get help from anyone who has replaced Surface Pro 11 Screen as it is confusing with the 5G and Non-5G Replacement Display. Though they look exactly the same in picture, they are separately listed.
da
Hi @bloodyprince
Looking at the parts list for both models and based on the different part numbers for the OLED panels I'd say that they're not interchangeable.
Usually manufacturers don't use different part numbers for the same part if it is used in more than one model (it would be too confusing) and if other similar parts are compatible they will list them as a substitute in the parts list (as shown below)
Surface 11 Pro for Business parts list
Display Module – OLED sku# 30H-00001
Surface Pro 11th Edition 5G and 10 with 5G for Business Part List
Display Module, OLED (Snapdragon Only) sku# 40C-00001, substitute sku# EP2-68362
Punteggio 0
Aggiungi la tua risposta
Bloody Prince sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 46
Tutti i Tempi: 125
