Salta al contenuto principale
Whirlpool WFG525S0HV0 - Err F2 E1 - Replaced Sensor and Panel
I moved into a new place with a Whirlpool WFG525S0HV0 and it started to display an F2 E1 error code after using the oven function.
So far, I've tried replacing the temperature sensor that may relate to F2, replaced the control panel and re-seated the stove grate in accordance with F2 E1. It still shows.
Does anyone have a wiring diagram/schematic for this model or know what the cause may be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @a_scerba
According to p.6 of the tech sheet an F2:E1 error code is a shorted keypad or possibly a faulty control board.
Follow the corrective action procedure shown for the error code to determine whether it is a faulty keypad or control board.
If there is a faulty part and it needs replacing here's the parts list for the model. Locate the part number for the wanted part and search online using the part number to find suppliers that suit you best.
Punteggio 1
If you are lucky u might find the service info tucked away someplace inside the stove. Per the F2 E1 error, since you replaced the contol panel, which might have been defective, the new issue might be the flex cable not being installed properly. Or the problem might be the main control board and not the control panel. Unfortunately, replacing parts might be the only option.
Punteggio 0
1 Commento:
You might find the manual on the back of the stove.
da
Aggiungi la tua risposta
Alex Scerba sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 19
Ultimi 30 giorni: 65
Tutti i Tempi: 213
