Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2191 Domande Visualizza tutte
Home botton can rotate 360 degrees
After my hubby replaced my cracked screen all was well Intill I noticed the home botton is kinda loose and can spin. Is also not as responsive as before. He opened the phone up again but couldn't figure it out. Any help would be greatly appreciated!
Thanks kindly
Jessica
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
It sounds like the rubber gasket in the home was removed when he fixed the cracked screen. If this is the case, you can purchase a new home button here and it's fairly in-expensive. It's also easy to put back in the phone. I hope this helps.
Punteggio 1
Aggiungi la tua risposta
Jess sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,955
