Salta al contenuto principale
L'OLPC XO-4 Touch è identificabile dai quattro piccoli punti sul retro della copertura della cerniera dello schermo.
Laptop not booting, 00 error on screen
My XO-4 has power but won't boot up. If I hold down the game buttons while turning it on, it shows this 00 on the screen.
Immagine
Otherwise i get just a blank white screen. It booted up normally a few times before but now only the power button seems to work. I don't know this laptop's history as I got it second hand.
UPDATE: a power refresh had no effect, changing the clock battery didn't fix it either. I got the laptop to boot up once, to the hardware self-test (which it passed). But then the 00 screen came right back.
After some research I suspect a firmware problem. One of my comments below was overly optimistic - OLPC's own wiki says the 00 screen is an "early" error code:
But what error does "00" mean?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @sparkysgadgets
Try a full power refresh and check if that resolves the problem.
Open the laptop and remove the main battery and the coin cell battery which is plugged into the motherboard.
Here's the ifixit OLPC XO-4 Touch repair guide that will help.
The coin cell battery can be seen in Step.18 of the motherboard replacement guide - see image below.
When the coin cell battery is out measure its voltage. If it is <2.6V DC or if the battery is >4-5 years replace it.
Press and hold the Power button operated for 30 seconds and then release it.
Reconnect the coin cell battery, reinsert the main battery, reassemble the laptop and check if it turns on OK
Immagine
(click on image)
Punteggio 1
1 Commento:
I've just tried removing and reseating the main battery and the coin cell, but nothing changed - I get the same error or the blank screen. I'll have to try something else...
da
A̶h̶a̶... t̶h̶e̶ "0̶0̶" s̶c̶r̶e̶e̶n̶ w̶a̶s̶n̶'t̶ a̶n̶ e̶r̶r̶o̶r̶!̶ It was. Even after I took out the main battery and replaced the clock battery, I kept getting the "00" screen (instead of the "Release the game keys to continue" screen).
Just once the laptop randomly booted: I held the game keys down much longer, until the "00" started counting other numbers (down from 60??) and then I kept holding them until I got the "Release the game keys to continue" screen.
But that only worked once :(
Punteggio 0
1 Commento:
Nevermind, the 00 is an error... my laptop only booted once :(
da
Aggiungi la tua risposta
Sparky sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 15
Tutti i Tempi: 90
