Salta al contenuto principale
The Ford Freestyle was a crossover utility vehicle that preceded the Taurus X
Open or short in EGR
How do I reset it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
@jessecavaness you are not giving us enough information. It does sound like you may have received a code like P0403 or P0405 from a scan. There is usually no resetting but you will have to determine what has failed. Could be the EGR valve (start with that one) or a bad sensor, bad wiring or loose connection or even a MAP sensor malfunction. Depending on the error code you have (let us know what the exact code is), check something like this video to check your EGR flow.
Punteggio 2
Aggiungi la tua risposta
Jesse Cavaness sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 27
Tutti i Tempi: 27
