Salta al contenuto principale
Released Jan 19, 2022, via an IndieGoGo Campaign. Has no visible model number
My lens cap broke If I put gasoline glue on it, it will stick?
Questa è una buona domanda?
Punteggio 1
1 Commento
Our confusion comes from your use of the term "gasoline glue". Are you referring to a type of adhesive used to seal leaking gas tanks? If so, that probably wouldn't be my first choice unless you don't have any other glue available.
We're talking about a pair of sunglasses, right? What exactly do you mean by "lens cap"? Are you talking about the frame that holds the lens in place? How is it broken; did it come apart or is the plastic snapped? A picture might help if you can add one to your question; this guide will help.
Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@grykbx7xmuhqfpy not sure which lens cap you are referring to, but gasoline will most likely melt and destroy your lens cap. HDPE plastics are pretty much the only ones safe to use with gasoline. Do NOT use gasoline for your lens cap!
Punteggio 1
2 Commenti:
Ok thanks(I'm referring to the plastic around the lens.)
da
@grykbx7xmuhqfpy Gasoline would definitely not be a good choice :-)
da
Aggiungi la tua risposta
------ sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 49
Tutti i Tempi: 102
