Salta al contenuto principale
Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
What are all the reasons why the engine overheats in a 2003 toyota cam
What are the all the reasons that the vehicle overheats in a toyota camry 2003?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@amachobria57095 that is a very generic question. Here are the most common causes for the overheating:
  • Low Coolant or Leaks
  • Stuck Thermostat
  • Failed Radiator Fan
  • Faulty Radiator Cap
  • Blocked Radiator
You will need to be a bit more specific with your question so we can narrow it down. It will help if you let us know what the exact issues with your Camry are. Also, let us know what you have already checked and what you have already tried to fix it. Let us now what engine size your Camry is.
Punteggio 2
2 Commenti:
100% agree with @oldturkey03's assessment, but I might add one more; a blown head gasket can easily allow hot exhaust gasses into the cooling system causing it to get hotter than it normally would, leading to overheating.
Blocked or kinked radiator hoses can cause this too, but that's not a common problem.
da
Low engine .oil can also cause overheating of the engine.
There still may be enough oil so as to not cause an oil pressure warning though
da
Aggiungi la tua risposta
amachobrian648@gmail.com sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 54
