Salta al contenuto principale
Guide di riparazione, smontaggio e informazioni sulla risoluzione problemi per la terza generazione del controller Sony PlayStation 5 DualSense. Identificabile dal numero di modello CFI-ZCT1W e dal modello di scheda madre BDM-030.
Orange light rapidly blinking after fully charged
Hello. I decided to change the sticks on my DualSense (motherboard BDM-030) for new ones with Hall effect. After soldering, during the first attempt to power on the gamepad, I received three short orange blinks when connecting the battery or USB cable. After several attempts to power it on, it suddenly started working normally. So I was glad and finished the manual calibration and then the software calibration.
I assembled the gamepad fully and connected it to the tester. During these tests, I found that the speaker is not working (one contact was bent, so I fixed it later) and both types of vibration are not working (wires are soldered correctly). Everything else looks good, except for the battery, which shows a charge of 0-9%. I charged the gamepad for several hours and saw that after a full charge, the orange light blinks rapidly. After connecting it to the tester again, it showed the battery charge jumping from 0-9% to 100% and back.
Visually, I can't find any missing elements. I don't see any shorts for now. During the removal of the old sticks, I damaged a few traces near the stick buttons, but it was just the green mask being removed.
In conclusion, the symptoms are:
  • Battery charge jumping from 0-9% to 100% when fully charged.
  • Speaker not working (even after fixing the contact).
  • Both types of vibration not working.
  • The gamepad powers off after a few seconds if connected wirelessly.
Maybe someone has had a similar problem and knows how to fix it? I found one topic with similar symptoms, but there was no solution. I will be grateful for any help.
Immagine
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi!
Maybe the board went too hot and something got damaged there :(.
Just to be sure, did you tried another battery and speaker? Just to be sure.
In this case it could be a lot, take a look at all the traces and also the power ic.
It could be a lot of things which makes this difficult to see where the issue is…
Punteggio 1
4 Commenti:
With other battery and speaker same symptoms. I removed installed Hall sticks and nothing changed unfortunately.
da
Okay, then it's most likely the power IC or the board had too much heat. I would replace that IC and see what happens!
da
Thank you for helping. Unfortunately I was not able to fix so sold it for parts.
da
Okay. Thanks for letting us know! Have a great day!
da
Aggiungi la tua risposta
Serhii Zastavnyi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 47
Tutti i Tempi: 221
