Salta al contenuto principale
Il Dell XPS 13 7390 è un portatile compatto e leggero del 2019, dotato di processore Intel Core di decima generazione, display InfinityEdge da 13,3 pollici (spesso 4K UHD) e un telaio in alluminio sottile e robusto. Tra i punti di forza figurano prestazioni elevate per la sua categoria, Wi-Fi 6 e una connettività solida tramite due porte Thunderbolt 3. I critici sottolineano che si affida molto all'USB-C e che manca di una tradizionale porta USB-A. Non confondere questo portatile con il Dell XPS 13 7390 2-in-1, simile ma con un display ripiegabile a 360 gradi.
Dell Notification "Your battery has failed"
I recently installed a new battery purchased from ifixit. The new battery appears to be working normal, like new. However, on occasion I get a Dell notification that "Your battery has failed". Is there a way to eliminate this notification.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi @williamh81520
Try uninstalling/reinstalling the Microsoft ACPI compliant control method battery drivers in Device Manager and check if that resolves the problem.
To get to Device Manager in Win10 (or Win11) press the Win key + x key (both keys together) and select the Device Manager link in the menu box that opens.
When in Device Manager scroll down to Battery → right click on the Microsoft ACPI compliant control method battery entry in the category → Uninstall device and follow the prompts.
When completed, close Device Manager and any other open windows and then restart the laptop in the normal manner.
Upon restarting Windows will reinstall the drivers. Check if the notification is still there.
Punteggio 0
This usually happens because Dell’s BIOS is strict about battery identification and health reporting. Third-party batteries (including iFixit) can work perfectly but still trigger false “battery failed” warnings. To reduce or eliminate the message: update your BIOS to the latest version from Dell, then reboot. Enter BIOS (F2 at startup) and reset settings to default. In Windows, update Dell Power Manager and chipset drivers. You can also disable battery health notifications in Dell Power Manager. If the warning only appears at boot, it can’t be fully removed—Dell hard-codes it in BIOS. As long as charging and runtime are normal, the battery is safe to use.
Punteggio 0
Aggiungi la tua risposta
William H sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 44
Tutti i Tempi: 275
