Salta al contenuto principale
Digital home cinema speaker system. Sold from 2011-2014.
Why don't any light come on the speacher or the subwoofer
  • Why don't any light come
  • on the speacher or the subwoofer
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • If there is NO POWER at all: You must trace the power flow from the source. Start at the AC Input Cable and move through the power supply stages:
    1. AC Input & Fuse: Check for continuity at the fuse.
    2. Bridge Rectifier: Ensure AC is being converted to DC.
    3. Standby Circuit: Look for the 5V Standby voltage. If this voltage is missing, the system will never boot or show any lights.
If Power is Present but NO LIGHTS
​If the unit functions (produces sound) but the LEDs are dark, you must perform a Reverse Trace (Back-tracing) from the point of failure:
1.  At the LED Pins: Measure the voltage at the pins supplying the lights.
2.  Back-trace the Rail: If there is 0V at the pins, trace the circuit backward to the LED Driver or the Controller IC.
3.  Check the Interconnects: Inspect the ribbon cables between the main logic board and the display panel.
4.  Find the Breaking Point: Continue tracing back until you find the point where voltage is present. The component just after that point is your culprit.
Punteggio 0
Aggiungi la tua risposta
Rickey Williams sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 152
