Salta al contenuto principale
La Grand Prix ha ricevuto un aggiornamento per il 2004 su una versione rivista della piattaforma GM W ed è stata presentata al Chicago International Auto Show il 7 febbraio 2002 come Grand Prix G-Force Concept.
Transmission not shifting to fourth gear
No fourth gear
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I'm assuming we are talking about a manual transmission vehicle. If so, it's possible something has gotten jammed in the space where your shift lever goes for 4th gear. Otherwise, you likely have worn out the syncro mesh on that gear and the transmission will need to be serviced by a mechanic.
Punteggio 0
2 Commenti:
Hi @valmartman
8th Gen Grand Prix (2004-2008) only came with automatic transmission (AT) although they did have a driver initiated manual up/down shift feature known as TAPShift.
Cheers
da
Oh gosh, then check your transmission fluid, that can cause all sorts of weird behavior. And then take it to a mechanic! Automatic transmissions are complicated as heck.
da
Aggiungi la tua risposta
charles schaefer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 18
Tutti i Tempi: 134
