fixing a NOCO GB50 - replacing buttons?
Like many I have an issue where the NOCO GB50 won't power on. It appears to be the buttons on the GB50. NOCO for whatever reason uses cheap parts that fail after just a few button presses.
Another ifixit showed the buttons here:
My question is, how do I disconnect the battery from the circuit board? It seems to be hard soldered on. I understand I can't desolder/solder the buttons without taking off the battery first otherwise I could seriously damage the device. Any advice on this?
Thanks!
Questa è una buona domanda?
1 Commento
@ztwrhk3g6luccw6 double check that. The battery should only be held in place with some double sided tape. Use a small thin metal scraper and see if you can shim it in between and separate the battery from the board that way.
da oldturkey03 Condividi
