Salta al contenuto principale
Guide di riparazione e documentazione per lo smartphone Google Pixel 6a con 5G. Lanciato a luglio 2022.
Pixel 6A Dead in Morning after overnight charging
Problem: After an overnight charging of a functional device, I woke up to learn that my phone is not responding at all. Dark Screen. After I pressed the power button or connect to the charger, there is no sign of life.
Google's response was to take it to the local Ubreakifix, authorized repair center. The diagnosis from the repair center was no warranty coverage, battery swap did not fix the issue, return the phone at no charge.
After getting the phone back, observing/realizing that it has an audio ding to the charger connection, which was not there before. Screen is still dark and a short double haptic response when I hold the power button. No images available as teh screen is still dark.
Looking at the experts here to advise on potential failure modes and solutions, repair approaches to help with.
thanks in advance, best regards.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Your initial problem sounds like what my 6 Pro did; one morning it wouldn't turn on, just D-E-A-D, dead. After exhaustive troubleshooting I ended up replacing the motherboard, which fixed the problem.
However, given your is now showing signs of life, the symptoms you describe are what I'd expect with a dead screen. First thing I'd do is open the screen up and double-check the connection between the screen and the motherboard; if that didn't get hooked back up again then you'd definitely see a black screen. The display connector is only held in by a spring clip, not screwed down like the 6 Pro, so you'll want to verify the clip is fully engaged and the connector completely seated.
You might try a USB-C to HDMI adapter and see if you can get a picture on a TV or external monitor. If so, your phone is definitely alive and there's an issue with either the screen or the connector.
Check those things out and let us know what you find. I did have my niece's 4XL that looked completely dead but came to life after I had unplugged the battery for a half hour while I looked for issues. Not finding anything, I plugged everything back in and was quite surprised to find that everything now worked like nothing had ever been wrong. Literally the only thing I did was remove the screen and unplug the battery, so I have to wonder if somehow you've encountered the same sort of issue and maybe the screen didn't get plugged back in fully when they put it back together.
Punteggio 1
1 Commento:
Thank you @dadibrokeit - Jerry. I will keep you posted on how this plays out.
da Condividi
Aggiungi la tua risposta
NJS sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 9
Ultimi 30 giorni: 29
Tutti i Tempi: 328
