error 13 iPhone 3GS
hi i keep getting error 13 when i try to restore my phone ,can any one help
Questa è una buona domanda?
If you tried a different cable and usb port and still have this error try this.
Step 1. close out itunes and disconnect your phone
Step 2. turn your phone completely off
Step 3. relaunch itunes
Step 4. plug in the usb end into your computer, but do not connect your iPhone yet
Step 5: This is the somewhat tricky part....hold down the round circle home button while you plug in your iPhone.
This is should bypass any software currently on the phone that is corrupt and do a fresh install. Of course you probably already know that all information will be lost from your phone - so hopefully you backed up before the crash.
And if Mayer's solution fails, you may need to put it into DFU mode. You can do that by following these steps:
Cheers!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 4,836
1 Commento
Is your iPhone jailbroken? A jailbreak can sometimes make it much harder to restore.
da Josh Calvetti
