Salta al contenuto principale
Lo smartwatch di settima generazione di Apple, con connettività cellulare opzionale, rilasciato il 15 ottobre 2021.
Will I be able to repair rear cover adhesive without front assembly?
I found a guide for replacing the rear cover/sensor on the Apple Watch Series 7 that instructed removing the front display and battery for swapping the rear cover. However, I do not need to replace the rear cover. It is still functional. The watch charges in the sensor works, but the gasket and adhesive sealant failed and The gasket is hanging out of the watch body, see the attached picture.
  1. Am I missing something other than the rear cover adhesive for this repair.
  2. Will I be able to do this repair without removing the front display and battery?
Thanks for the help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
It’s tricky, the adhesive comes with a plastic backing that is tricky to apply with the rear cover hanging in place.
I suggest fully disassemble, clean the adhesive contact surfaces and apply new factory adhesive.
Punteggio 1
Aggiungi la tua risposta
Tancredo R sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 77
