Salta al contenuto principale
Why is my microwave not powering on and not working
It does not show any signs of turning on the fan in it does not even work
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi @rolandgyau
What is the model number of the microwave oven?
da
Aggiungi un commento
1 Risposta
Your Samsung microwave showing no power at all—no display, no lights, no fan, nothing turning on—is a common issue often called a "dead" microwave. Here are the most likely causes and step-by-step troubleshooting to try safely.
Basic Checks First (Safe and Easy)
  1. Power outlet and circuit breaker
  2. Plug another appliance (like a lamp or phone charger) into the same outlet to confirm it works.
  3. Check your home's circuit breaker panel—look for a tripped breaker for the kitchen/microwave circuit and reset it if needed.
  4. Power cycle/reset
    Unplug the microwave from the wall for at least 5–10 minutes (some sources recommend 30 minutes).
  5. Plug it back in and try again. This can reset temporary glitches or clear minor overheating protection.
  6. Child lock or demo mode (less likely since there's no display)
  7. If it suddenly gets power, check your user manual for how to disable child lock (often holding "0" or "Stop/Clear" for 3–5 seconds) or demo mode. But with no display, this probably isn't the issue.
If these don't work, the problem is likely internal.
Punteggio 0
Aggiungi la tua risposta
Roland Gyau sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 36
Ultimi 30 giorni: 117
Tutti i Tempi: 479
