Salta al contenuto principale
Repair and troubleshooting information for the HP EliteBook 840 G5, an HP laptop part of the HP EliteBook series. Released in February 2018.
My laptop is not turning on
I have changed the battery, the battery charged but still refused to turn on. I did a hard reset but still no response. I have tried charging the battery for long also changed the battery but still same problem. What can I do to resolve this ?
Questa è una buona domanda?
Punteggio 0
1 Commento:
@zeroone01 does it show you any sign of life? Any LED that turns on when you plug you computers AC adapter in?
da
Aggiungi un commento
1 Risposta
What type of charger are you using - barrel or USB-C? Sometimes with a weak or new stale battery, these G5-G10 machines do not properly charge without using the barrel adapter if you primarily use - the G11 obviously isn't affected being USB-C only but it's a thing. You can use a 65W or 90W slim blue tip barrel adapter like this: HP 65W 19.5V AC Adapter - 710412-001
If that doesn't wake it, try to remove the CMOS battery, hold the power button for 30 seconds, reconnect the CMOS first then the primary - give it a few minutes as the SureStart boot routines cause it to flash the caps lock key for 60-90 seconds due to the memory retraining and "default settings" rollback being more time consuming on the SureStart hardware.
If that doesn't work, it might be the motherboard :-(. HP Consumer has a lot more issues with that, but HP Commercial PCs usually fail due to BIOS passwords being there's no master password and the removal process is... something. That said, the HP Part# for the power button is L14374-001 if you want to try it for ~$20.
The HP SM can be found here: https://kaas.hpcloud.hp.com/pdf-public/p...
Immagine Provides power to HP laptops by converting AC to DC current.
Prodotto
$34.99
Punteggio 0
Aggiungi la tua risposta
Somtochukwu Ogolo (Lordfoes) sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 15
Tutti i Tempi: 87
