Salta al contenuto principale
1975-2011 (L'immagine mostra una Grand Marquis del 2008)
How to stop my car from overheating?
I changed the radiator and coolant cap but now I think it’s a leak I don’t how to find and someone told me to change the thermostat but I just want to ask.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The thermostat is the first thing to check,.if you can change it yourself remove it and put it in a pan of boiling water and see if it opens or you can run engine until it gets hot and give the upper lower hoses ,if.one is hot and other is cold there is the.answer and.you can take cap off cool and start it watching for flow after warm up. Best o luck
Punteggio 0
Aggiungi la tua risposta
Kailib Thornton sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 6
Ultimi 30 giorni: 28
Tutti i Tempi: 180
