Salta al contenuto principale
Why isn't my TV remote responding to my commands?
I put the charger on and then I pressed all the buttons, it doesn't work, but the LED doesn't light up.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Lenovo devices may experience Wi-Fi connectivity issues for various reasons, some software-related and others hardware-related. Here are the most common possibilities:
  1. 🔎 Common Causes
- Network adapter driver not installed or outdated: The problem often lies with the Wi-Fi driver.
- Incorrect network settings: Such as a proxy, VPN, or incompatible manual IP settings.
- Airplane mode enabled: Prevents Wi-Fi connection.
- The router itself: May need to be restarted or have its settings updated.
- Interference or weak signal: If the device is far from the router or there are many obstructions.
- Faulty internal Wi-Fi card: Sometimes the card is faulty or needs technical inspection.
  1. 🛠️ Practical steps to troubleshoot
1. Restart the device and router.
2. Ensure Airplane mode is turned off and Wi-Fi is enabled. 3. Delete and reconnect to the network by re-entering the password.
4. Try connecting to a different network to determine if the problem is with your device or the network.
5. Update your Wi-Fi driver:
- Open Device Manager.
- Locate Network adapters.
- Right-click on your Wi-Fi adapter and select Update driver.
6. Reset network settings:
- In Windows: Settings > Network & Internet > Status > Network reset.
7. If these steps don't work, try having the adapter checked or replaced at a service center.
📌 Conclusion: The problem is most likely with your Wi-Fi adapter driver or network settings. The quickest solution is to update the driver or reset the network. If the problem persists even after that, the adapter itself likely needs to be checked or replaced.
Punteggio 0
Aggiungi la tua risposta
Hojiakbar sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 9
