Salta al contenuto principale
Repair guides, disassembly, and troubleshooting information for the third generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-030.
My controller shows 3 blinking lights yellow
I have a PS5 controller and I was upgrading to hall effect sticks and one thing i did notice before i finished it was that the the button for L3 had some of its lines i brushed it The image shows how it got damaged and i dont know if that is the issue or something else. i havent soldered my vibration and haptic wires yet too or is it a flux short?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi!
First of all, I would repair the traces and get this fixed.
Then it's for the best to connect everything again and test the controller.
Here is a sample guide: How To Repair Damaged / Broken PCB Traces - 2 Great Methods
Please let us know how it goes!
Punteggio 1
2 Commenti:
Thanks, I will try it out as soon as I get some wire. One of my PCB pads was also missing, and I found a video from the same channel. I have a spare motherboard, which has a similarly sized pad, so I will scrape that one off and transfer it to the PS5 controller motherboard. I also found that one of my solder points was barely connecting to a different one, so it might be a short as well. I will be resoldering that, too. I will update ASAP.
da
Alright! Sounds like a lot to do! Good luck with the repair and please let us know how it goes :)!
da
Aggiungi la tua risposta
Elvin Eve sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 169
