Why is my MacBook not turning on?
Macbook not turning on. MagSafe charging LED not showing and usb c charging does not seems to work.
Left connected to dock with power delivery via usb c for 24-36 hours and when I came back it doesn't want to turn on
Questa è una buona domanda?
Are you sure the charger and USB-C cable are working? Is the MagSafe connector contacts clean and the MagSafe cable is not damaged?
What is the make and model of the charger?
And lastly can you plug a USB-C power meter in line with the charger so we can see the voltages.
da DanJ
@danj
1) The USB C charger is working as it charges my samsung s24u ultra.
2) The MagSafe cable looks clean and the contacts don't seem to be damaged.
3) The charger is the NOVOO USB-C Charger 100W
4) I have not currently got a USB-C power meter, I will have a look at getting one. Is there a particular model you suggest or is any fine?
da Muhaimeen Ali
@muhaimeenali - See if you can snag one of these UMLIFE 2PCS 360W USB C Tester Power Meter
da DanJ
@danj
Thanks, I'll let you know the results as soon as I get my hands on it
da Muhaimeen Ali
@danj
Hi, got the results,
Top left usbc port:
5.08975V
0.01200A
0.06118W
Bottom left usb c port:
5.09750V
0.01650A
0.08411W
Right Usb c port-
no results, was just off so I assume no power
da Muhaimeen Ali
Mostra altri 5 commenti
