Salta al contenuto principale
How do I fix the bottom left opening hinge
how do i fix the bottom left opening hinge it has popped the bottom rectangle panel above the speakers,
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @tylorbjornson
Here's the maintenance and service guide for the laptop series that should help.
It shows the procedure to safely disassemble the laptop so that you can access the hinges to find out what the problem is.
If it's a faulty part - hinge, lower case etc, that is the problem and needs replacing, there a parts list in the guide.
Search online for (insert wanted part number) only to find suppliers that suit you best.
Punteggio 2
Aggiungi la tua risposta
Tylor Bjornson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 32
Tutti i Tempi: 32
