Salta al contenuto principale
It works but it doesnt heat the food
The microwave is working, but when I put food inside, it doesn’t really heat it — it just warms it up a little.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta più utile
Hi @ahmed65821
Just a quick heads-up before you dive into microwave repairs: these appliances can be seriously dangerous if you're not trained. Even when unplugged, the internal capacitor can hold a lethal charge. If you're not familiar with high-voltage electronics, it's best to leave it to a professional.
That said, if you're experienced and know what you're doing, make sure to:
  • Unplug the unit and discharge the capacitor safely.
  • Avoid touching any internal components unless you're certain they're safe.
  • Use insulated tools and wear protective gear.
  • Double-check everything before powering it back on.
⚠️ Disclaimer: I'm not a certified technician, and this advice is for informational purposes only. Attempt repairs at your own risk. If in doubt, call a pro.
Sharing some nice repair blogs ....
https://jestineyong.com/category/microwa...
some components you need to check on, high voltage components: fuse, diode, capacitor and transformer.
Stay safe and good luck! 🔧
Punteggio 1
بما انه يعمل لكن التسخين غير موجود فالمشكل عندك اولا شيك على الفيوز ثانيا الكباسيتور ثالتا الدايود ان لم يكن واحد من هذه الثلاته يجب ان تشيك على ماغنترون
Punteggio 0
1 Commento:
اهم شيئ في صيانة الميكرويف هي السلامة لانه ان لم تكن فنيا فانتبهمن الكهرباء المكثف يجب تفريغه بعد ان تقطع الكهرباء عن الميكرويف ثم تسحب سلك توصيل الكهرباء السلامة اولا
da
Aggiungi la tua risposta
AHMED sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 22
Ultimi 30 giorni: 77
Tutti i Tempi: 652
