Joy-con too tight on the rail after reassembly
I recently changed the joystick and flexible sl/sr cables of my joycons, however the left one gets "stuck", and only comes off of the switch after i wiggle it. When i put it on the switch or take it off the switch i also hear some faint creaking in the middle of the process. and i believe its because of the fact that the rail is moving more "freely" now, as it isnt as snug as my other joycon. im worried it can break the rail of the joycon or of the switch. ive tried to tighten the screws, loosen the screws, but nothing works (possibly because the lower screw close to the rail got stripped, and even though its quite screwed in i cant do much abt it). any help? i didnt touch the screws that keep the shell and rail in place, the only ones i touched were: the external ones, the ones on the rail to keep sl/sr and sync buttons stuck, the ones on the battery side and the joystick ones
Questa è una buona domanda?
4 Commenti
Hi!
Can you share some pictures with us? That will make it more easy for us to check what's going on!
Aggiungere immagini ad una domanda
Thanks!
da koppie007
hey! once i get home i will totally do that!
da Gabriel Silva
Thank you!!!
da koppie007
@dan0 done! i also submitted s video but i think its not working... it was to show that on the lower part of the joycon, near the stripped screw, it creaks when pressed, and close to the joystick it doesnt
da Gabriel Silva
