Broken CMOS Battery Slot, is it repairable?
Hello everyone, I tried to reset the BIOS on my MSI B550-A PRO but the pins holding the battery did not retract far enough. A little bit of more force freed the battery but ripped the plastic form. While I won't have trouble now doing a reset, unfortunately the battery will not remain secure in the slot as the force of the spring pushes the plastic casing outwards. Now I would like to know if and how I could fix this and how cooked I am.
Questa è una buona domanda?
1 Commento
I would try to find a CMOS battery holder for the given battery that has leads which you can solder onto the broken holder in the system at worse. I would have offered one but I'm not sure which battery you need in this system. Can you tell us the needed battery so we can maybe aim you to a possible solution and maybe a picture of the broken holder as well to try to locate an exact replacement.
da DanJ
