Salta al contenuto principale
Why is my 2008 Cobalt LS not starting
I turn the key and I get nothing. It doesn't do it all the time but it does it frequently. Replaced the starter and solenoid, checked connections at the starter, changed relays around, changed ignition switch, and even tried to bypass all that and put in a start button (that worked when it was installed but now it doesn't) it really has me stumped. Does anyone have any other suggestions for this problem?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @joevenanzio
Do the appropriate instrument panel lights turn on when you operate the ignition key?
Here's the start circuit wiring diagram that may help you to find out why it's not cranking.
(click on image)
Punteggio 2
1 Commento:
Thanks for the diagram
da
Aggiungi la tua risposta
Joe Venanzio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 88
