Salta al contenuto principale
Lanciato a maggio 2020, il MacBook Pro da 13" ha dei processori quad-core Intel di ottava generazione Core i5 e i7, e grafica integrata Intel Iris Plus 645. (Modello A2289/EMC3456 con due porte Thunderbolt 3)
MacBook Pro 2020 (A2289) battery replacement issues.
I have just replaced the battery for the MacBook Pro 2020 (A2289). The laptop will only now switch on with the battery charger connected. The computer does not recognise the battery on coconut battery and the battery icon has an X inside it. System settings state that the battery is fully charged at 100%. When I remove the charger cable the computer turns off. I have ordered a replacement data flex cable incase that is the issue. Is it likely that this is the issue ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Review Steps 8 through 12 in this guide Sostituzione batteria MacBook Pro 13" 2020 con due porte Thunderbolt as the battery data cable is either not connected within the ZIF connector or the connector is damaged, or the cable is damaged and will need to be replaced. Here's one source TheBookYard UK - MacBook Pro 13" BMU Flex Cable (2TB 16-22)
Punteggio 2
1 Commento:
Thank you for your reply , I have ordered one now and will let the forum know once fitted , just quite worrying as I’m not really an IT person. Thanks again
da
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 69
