Salta al contenuto principale
Il controller analogico DualShock 2 è apparso per la prima volta con la PlayStation 2 e presentava solo piccole modifiche estetiche nelle posizioni delle viti, etc.
both analogs are sqeaking and glitched.
even when analogs are centered, the input is as if its going straight down-right.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I did have a controller that did this as well. The first step is to take apart the controller using the IFIXIT guide. The first thing I would recommend doing is spraying a light amount of compressed air into the analog stick. This is what fixed the controller for me. Next, I would take a cotton swap and clean up all of the old residual lubricant and replace it with electronics safe WD-40. If that works, then great! If not you will probably have to replace the joysticks. You could order a decently cheap pair of analogs from this link PS2 Analog Sticks (or any other ones like this). There is also a guide on how to replace these on IFIXIT.
Punteggio 1
1 Commento:
thanks kind sir, i havent tried it yet but ill let you know when i do. 🙏
da
Aggiungi la tua risposta
Yassin Sherif Saleh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 55
