Salta al contenuto principale
Repair guides and support for your Panasonic microwave.
Panasonic NN-SD27HS works only for 2-3 sec. false overheating error?
Hi,
this is my first question here.
My Panasonic NN-SD27HS performs very annoing error for quite a while.
It works perfectly ok, but with no reason sometimes it stops working after 2-3 seconds. Magnetron and turntable are off, only overheating fan is on for next 2 min.
Seems like defective temp. sensor, but this malfunction appears/disappears with no explanation...
No error code is displyed...
sometimes it helps, if I reduce the power to 440W
Can it be a kind of loose contact around the temp. sensor, or a capricious door switch mayby?
really no idea where to start checking....
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @jaro77159
Here's the service manual that will help.
Go to p.18 Sect. 9.1. (Troubleshooting) Oven stops operation during cooking, to see the possible causes for why cooking stops within 3 seconds of starting
Punteggio 1
Aggiungi la tua risposta
jaro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 174
