Salta al contenuto principale
Il terzo aggiornamento del controller wireless dell'Xbox è stato rilasciato a novembre del 2020, insieme all'Xbox Serie X ed S. Il controller è anche compatibile con i precedenti modelli di console Xbox One e i PC.
How can I remove stuck pin?
Pin is mushroom at the top, meaning no grip, but at the bottom it has grip. I used a desoldering gun and wick still didn’t work, so I got a hot air station. Still doesn’t work. Temperature I used was 300-400°C for 15 seconds or more, but it depends. Solder is lead-free.
Questa è una buona domanda?
Punteggio 0
4 Commenti:
Hi!
Are you able to upload some photos? This will make it easier for us to come with an answer! Thanks!
da
Mybad updated picture uploaded
da
@dan0, for equipment, I have an atten heating station, a Hako desoldering gun, and a soldering iron Hako 8888DX.
da
Thanks! Do you have a hot air station? Would try that and then try with tweezers to get it out. Make sure you use flux first. It should come out.
da
Aggiungi un commento
1 Risposta
I would add flux and then solder, heat, and try to pull with tweezers. Might need to increase the heat as well. Hope this helps.
Punteggio 0
2 Commenti:
I tried using that method to increase the temperature, but nothing happened. Is there a way I can demonstrate it to you on FaceTime?
da
I’m thinking about getting a another daughter board but at the same time what if that issue come up again
da
Aggiungi la tua risposta
randy 098 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 60
