System unit shutting down after awhile
The system unit shut down after a while, what could the the cause and the solution to the problem
Questa è una buona domanda?
A dusty fan and dried thermal paste on the CPU can contribute to the PC shutting down to protect the CPU from overheating and being damaged.
Check if the fan needs cleaning and also if the thermal paste on the CPU needs to be refreshed.
Here's the ifixit HP Elite Mini 800 G9 Teardown guide and also the Come applicare la Pasta Termica guide that will help you access the necessary components i.e. fan and CPU
Guida
Difficoltà:
Moderato
5 - 20 minutes
Guida
Difficoltà:
Moderato
This is just a guess, but Widows has a Hibernation mode that is meant for Laptop computers to save battery life. This is different then Sleep Mode and computers can be hard to wake up from it. You might try going into power settings and changing Hibernate from X minutes to Never.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 23
Tutti i Tempi: 83
