Salta al contenuto principale
The Nothing Phone (1) is the first phone produced by the Nothing company.
My phone is not charging wirelessly
I charged my phone with a wireless charger and it is not charging
Questa è una buona domanda?
Punteggio 1
2 Commenti:
Hi @emadahmad
Does the battery in the phone charge when you use a compatible wired charger?
da
Is the wire charging working, or is the problem severe than that?
da
Aggiungi un commento
1 Risposta
If wired charging works but wireless doesn’t, try removing the case, ensuring the phone is correctly aligned on the Qi pad, and testing another charger. If neither wired nor wireless works, it may be a hardware issue. After repairs, check the wireless coil alignment, back cover snaps, and spring contacts—misalignment or poor contact can stop charging. If all else fails, inspection or professional repair may be needed.
Punteggio 0
Aggiungi la tua risposta
Emad Ahmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 136
