Salta al contenuto principale
La Nintendo DS Lite è stata rilasciata nel 2006 subentrando alla Nintendo DS. Lo smontaggio di questo dispositivo è semplice, il che ne rende facile la riparazione.
Why won't my Nintendo DS lite charge and not turn on?
I have charged my Nintendo DS lite for a few days and the light still won't come on does it have something to do with the battery or no
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Yes, it could be the battery! Could also be a fuse on the motherboard.
First, I would try to replace the battery (as this is the most easy thing to do first) and see if it want to turn on. If not, charge it for a bit and see if it comes up.
If this didn't worked, then open it up and test the fuses with a continuity test, if you hear a beep, then they are fine, if not, it need to be replaced.
The fuses are labeled with "F1", "F2" on the motherboard.
Please let us know how it goes!
Punteggio 1
Aggiungi la tua risposta
Heaven Morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 39
