Mayer idea is right. Usually, the culprits for a bad backlight are three. Well, four, but the latter one is so rare to be utterly nonexistant.
1. A damaged inverter is the first one, and it's usually responsible for an absent, or dim backlight.
2. The second culprit is the inverter cable. You must however notice that a damaged or frayed inverter cable may look fine, but actually may be internally damaged, bent or broken. The telltale symptom is a blinking backlight, that goes on and off when you jiggle the monitor, until it's utterly trashed, and then it gives an absent backlight.
3. The third cause is a faulty CCFL lamp. A CCFL lamp is... picture it a small neon, lodged on the back of your LCD. When it's aging, it starts to give off a yellowish or pinkish hue, until the light dies.
The fourth cause, negligibile and never observed by myself, is a bad capacitor near the Inverter Cable.
You found a frayed white cable however. Check with mayer's guide: there's a possibility it's one of the cables soldered to the CCFL lamp that connect to the Inverter.
I suggest you to try to fix the cable ASAP: I wouldn't keep a frayed cable near a hinge. However, if it's the white cable that comes out the LCD panel, as mayer instructed you, you may have in your hands a mild case of case 3: your CCFL lamp is fine, but its connection to the Inverter is busted.
I doubt you fried the CCFL lamp, but since you're at it, you may fix the cable.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti
Er.... top half of the casing, as in, behind the screen. Just making sure I don't sound like I mean near the trackpad.
da Kate
Please give us the last three figures of your serial number so we know your exact machine.
da mayer
Last three of serial are 0P1
da Kate
Apple MacBook "Core 2 Duo" 2.4 13" (White-08) Specs
Identifiers: Early 2008 - MB403LL/A - MacBook4,1 - A1181 - 2242
da mayer
