Salta al contenuto principale
Una Roku TV da 32" rilasciata da TCL nel 2018.
Corner of the screen was hit with something and now where it was hit t
The corner of the screen was hit with something so where it was hit the screen is out but the rest of the TV works fine. How do I get the corner fixed.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @quinnfrost
If you mean that there's no image on the screen in the area where the corner has been damaged, then the screen will have to be replaced as it cannot be repaired.
Disconnect the power to the TV and then remove the back cover and check if you can locate the make and model number of the LCD panel. This will be different to the TV model information because TV LED panels are made to order by specialist screen manufacturers and not the TV maker themselves (except perhaps, Sharp, Samsung, Toshiba and LG who do make their own).
If you find the information, search online using that information to hopefully find suppliers of the screen.
Be aware that a replacement TV screen can cost nearly half as much as a new TV so perhaps a better option is to advertise the TV as TCL ( insert full model number) faulty screen, good for parts, to try and recoup some of the cost towards a new TV. Working TV boards are always in demand.
If you can't find a replacement screen you may just have to live with it as it is.
Punteggio 3
2 Commenti:
I just hit mine accidentally with a tv remote ,trying to hita f fly, it damaged a small area of about 3h x 4 inches wide right ate the top left corner area made a small circular smash on it , !#^& me off , have had this tv over ten years no issues . and yes mine is a ROKU SHARP 50" screen Model number should help now right ?
da
P.S. rest of the screen works , but I want to see how much to gt it fixed , especially since mine is from ROKU SHARP.
model #LC-50LBU591C
PRODUCT DESCRIPTION;50 " UHD 4K 60HZ LED TV ROKU
SKU#10575044 Maybe someone willsee this and find outt anything , i am gonna lookit up now
da
Aggiungi la tua risposta
Quinn Frost sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 371
